I am looking for some help running the plumbing on my 18’ round semi above ground pool
I have an aqualcal t75 heat pump
hayward CL200 inline chlorinator
hayward 1hp pump and cartridge filter setup
and i also want to have a small waterfall feature at one corner of the pool
i want to run this off of the filter pump also
everything is setup approximately 20’ feet away from the pool and i plan on running the pvc piping in the ground
this is all brand new and will be the first install on the pool
i am looking for what size pvc lines i should be running i believe all of my equipment has 2” inlets and outlets
does that sound correct ?
where should i be installing check valves for when i want to drain all the lines for winterizing ?
any other tips or advise to make this go as easy as possible
i am hoping to get it done this weekend
and get the pool going so the family can start using it
thanks for any help and advise
