I have a disease that causes my muscles to be in pain, and light swimming and movement in water is the only thing that gives enough relief. So I really need a good pool. I’ve done lots of reading here, and greatly appreciate the site and everyone on it. This is my first post. By Monday afternoon I need to decide whether to order a DIY insulated aluminum walls pool kit - the Hercules line by PlayGo pools (aka The Pool Factory and Alligator pools). An inground pool won’t work in my space for many reasons. Also, I only have 14’ 8” of space between a setback and retaining wall, and I want to do a 11’ by 44’ lap pool. So I’m limited to either soft-shell pools like Intex, Splash or Kona (that aren’t a good fit for my needs), or to Hercules … as Radiant & Doughboy won’t do custom sizes.
My challenge is the water would only be 45” high because the top of the inside of the Hercules pool wall is 49” after set-up. For my light exercises, it’s a lot better if it’s 48” or higher. So I’m trying to figure out if I can do one of the following to get more inches of water:
1) The pool walls are 3” thick with a 3.5” wide metal ledge at the top. Would it be feasible to do a poured concrete coping about 3” thick and 5” wide with 3/4” protruding on each side? Would I need to attach something like rebar to the top of the panels to give the concrete something to hold onto? As you can see at this photo of the panel - https://swimmingpool-discounters.co.../HERCULES-POOL-Panel-Thickness-1200x1600.jpeg - both sides have a recess. The water-side recess is reserved for the liner, but I could wrap the concrete down on the outside into the recess on that side to help secure it.
2) How good would it be to stack 2 pieces of composite pool decking on the ledge and screw them in? I found boards that are 5.5” wide. But almost all brands max out at 1” thick, so it would take 2 layers to get 2”, while poured concrete might get 4”, in which case I could have the water go up to near the top of the liner at 48 – 49” deep, and still have the water 4” below the top of the walls. It also seems like 2 stacked deck boards might look odd or half-baked. Or might have issues with water getting under them?
3) Any other ideas or products? If there is 2 - 3” thick composite coping that’s 4 – 6” wide, maybe I could screw it into the top of the wall. I can’t build a deck around the pool due to space limits, plus cost etc. The Hercules owner said it wouldn't void the warranty if I attach deck board or other things to the top ledge. You can see info and examples of the pool here - The Ultimate Pool Gallery | Wilkes-Barre, PA or here - 2023 HERCULES ON GROUND OR INGROUND ALUMINUM POOL FROM | swimming pool discounters. This photo is closest to how the pool would look in my case: https://swimmingpool-discounters.com/wp-content/uploads/2018/03/Hercules-Inground-4.jpeg
Hercules had an "early season" order discount of 18% that expired two weeks ago, but the owner agreed to give me an extension until yesterday (Friday). On Thursday, due to an issue on my end, he agreed to give another extension until this Monday. Thus I need to decide soon, but I'm anxious about whether I can increase the water height. So I really appreciate any input, advice, etc.
