I have owned my pool for eight years.
Increasingly, I am finding problems with it.
I just increased solar, and so I am trying to maximize solar energy use.
I programmed the schedule to run the pool pump from 10am to 4pm. However, the pump comes on really strong and then after five minutes shuts off, and then a few minutes later it comes back on again and then shuts off. it does this throughout the 10am to 4pm cycle. Hence, it might only be moving water a fraction of the time. During those six hours, however, if I go out to the variable speed pump, it says "display not active" and there is some pump activity, but just so slow that barely any water is moving.
The only way to get the water moving is to switch to time out or to schedule, and then in that case, I can program it and it will stay on the entire time.
Another way to get the water moving is to coincide the polaris cleaner schedule to be within the pool pump schedule, for example 11am to 2pm, and then the pump is moving water continuously but only during that pump time.
In this graph from my electrical consumption, you can see the pump turning on and off in the wee hours of the morning as well as during solar generation. The only continuous run time is during the cleaner operation
