Moved from HERE
I have a very new pool with all Pentair equipment. Yesterday a Pentiar licensed tech came to address and repair a water drip from the heater. All was good for several hours until I wenyt to activate and heat the spa. The remote would not respond to any command and the pump stopped working, Display in the main control box showed "error code 14"..Manual shows no error code above 6,. Main control panel will not respond to any command (even pool light). Heater flashes "Service" light, Remote control shows "Service" and will not respond to any button. This AM went out and hit F1 and the pump did start. Service light still on in the heater and the remote still only says :service. Ideas and suggestions welcomed.
