I totally missed this post this morning! And thanks about for the encouragement... it's needed!
Good Morning. Let's see if I can make some sense of this and start moving in the right direction. Feel free to correct whatever I have wrong.
You have a 24' x 4' AGP.
You have added 6½lbs of CYA so far. That's 65ppm CYA in a 12,000 gallon pool.
You have added "a bunch of algaecide" more than 4 gallons.
You've added a bunch of 50% Cal-Hypo. How much?
You've added 12 gallons of bleach.
You're testing with strips and a HTH 6-way test kit.
You're ordering a good test kit tomorrow (July/15/2010)?
And we don't know where you're located.
Does that about cover it?
I am in Nebraska, hot and humid!
Ordering new test kit tomorrow ( Pay day! )
I have added 25 lbs of the cal-hypo this year.
4 gallons of algecide
18 gallons of bleach this year
Now lets start fixing this thing!
What does your water look like today?
Run a full set of tests and post the numbers you get.
First thing you're going to need is a lot of bleach. Start with 15 large jugs.
Don't buy anything else until you get your TF-100 test kit and can test your water.
Spend some time learning to use Pool Calc if you aren't already familiar with it.
Pool is green and cloudy, more green than cloudy, I can see "algae dust" that settled on the ladder this morning.
My reagent test of the CYA has a low of 30, even past that I still can see the dot. ( you mix 7 mL of pool water with 7 mL of the reagent, shake, then pour into beaker until you can't the see the dot ) So whatever it is, it's under 30 for sure. Judging on what I could see of it at 30, it would be maybe 10.
I also tested the alkalinity while I was out, it was at 260 ppm. I did not test pH or hardness, but can run out and do that quick.
