Hey guys, need some help diagnosing a possible leak.
Short story, had to replace my motor as I had a cracked motor seal plate and water got into the motor. Rebuilt just about all of the pump with a new VS motor, seals, plate, gasket and impeller. Fired everything back up and I've got tons of bubble coming out of just 1 return (of 2) and lots of air in the pump basket. I'm pretty sure I had the same issue with the old motor, but I chalked it up to the motor going bad.
So far, I've backwashed a few times and shut off the main drain return and skimmer return. Shutting each one off doesn't change the air in the basket or the return, so I'm guessing it's a leak in the return? If it makes a difference, the return with bubbles is the closest to the pump. Also, I've run the VS motor at lower speeds to make sure I wasn't exceeding the flow the plumbing can handle.
What else can I check?
Appreciate the help!
