I'm not sure how, but my valve and heater configuration got messed up, and I'm not sure exactly how to get it all back. somehow it ended up in heat pump mode and the default valve configs were empty. needless to say my solar setup wasn't working very well.
Pool Spa Combo, with a single solar valve.
I have re-enabled solar, and made it active but this morning the pump wasn't coming on.
Is there a good set of instructions for getting the valves and the circuits and speeds dialed in as they are supposed to be?
I have other circuits with valves like pool cleaner and water fall working correctly. Pool / spa combo working right but the solar is not really working.
Last two days I just forced it on via the toggle switch on the valve actuator and turned the pump to a higher speed.
I want this back on autopilot. can anyone help ?
