mas985 said:
If your previous flow rate was 85 GPM, the low speed would be half of that. What is your filter presssure on high speed and how high is the pad relative to the water level?
I just guessed that my (hi speed) flow was 85 GPM, based on my old single-speed (AO Smith USQ1202) being a 2.2 tHp motor in a Sta-Rite Max-E-Glas II P4EA6G pump. I don't know how to estimate flow rate more exactly.
Your comment is helpful - I didn't know flow volume is linearly a function of RPM.
To answer your specific question, my filter pressure is 27 psi in hi speed now (with the new AO Smith B2983 2-speed pump); it's 12 psi when in lo speed. (My pressure gage is small and old and thus these numbers could be off by a couple or so psi either way.)
My new 2-speed motor runs at 3450 / 1725 RPM. If my estimated 85 GPM on high speed is correct, then now I must be running at 42 GPM. Assuming 42, and noting I have a 30 KGal pool, then that means I need 706 minutes to turn over the water 1 complete cycle, or 12 hours of running the pump at low speed.
Since I'm instead running at 21 hrs/day, that means I'm actually excessively turning over the water (1.8X each day). So it looks like I can cut back the running of the new pump to achieve just a 1 turn over per day objective. 21 minus 12 hours = 9 hrs/day savings, @ 335 W = 3.0 kWh further savings per day = another $110/yr savings. Now my savings is up to $182 + 110 = $292/yr (@ 10¢/kWh).
I looked at putting in a flow meter to get an accurate idea of my water flow. Unfortunately the one's that could interface into my energy monitoring system (see my signature) are expensive and thus not something I'm going to do at this time.
If someone can help me estimate what my high speed flow rate is, based on the equipment in my signature, and based on these measurements, I'd be very appreciative.
Filter pressure: 27 psi (hi), 12 (lo)
Current: 10.0 Amps (hi), 1.5 (lo)
Motor nameplate numbers:
RPM: 3450 (hi), 1725 (lo)
Current: 10.0 Amps (hi), 1.6 (lo)
HP: 1.5 (hi), 0.19 (lo)
SF: 1.47 (hi and lo)
Thank you.
Best regards,
Bill
