Thanks PJT.
Regarding the depth, I really struggled with it. I agree that 3' is shallow but I was afraid that 5' might not be deep enough so when I was thinking of the different combination of shallow/deep depth and the required slope, it seemed that it needed to be 3' on the shallow end to allow average sized people to walk 2/3 of the length without having to swim. But this is interesting what you are saying about the deep end. Currently the setup is such that the last 5' would be 6' deep and the first 5' after the stairs would be 3' deep like in the picture below. If I were to change the deep end to 5' instead, I would have to think about how to get to 4' sooner and have a gentle slope.
Regarding the filter I'll look at the 520 filter.
It seems nobody likes that SVRS pump. Originally I wanted to go with the Whisperflo 011533 and Easytouch but ended up reading on this forum about intellicenter being a better choice and I think I need the interlliflo for that, so I'll look into the one you mentioned.
Regarding the volume it will be slightly less than 20k gallons so we should be good with the IC40. And yes the lights will be away from the house.
When you say main drain is optional, would you just go with the 2 skimmers and would that be enough ? wouldn't it require more frequent vacuuming because dirt would tend to go to the bottom of the pool?
Regarding vacuum. I didn't plan for suction vacuum line as I wanted to opt for one of those robots connected to power or the battery powered ones which seems the way to go. In a new build would you put a suction vacuum line nowadays ?
The separate pump for the SPA is for the reason Allen mentioned that it's hard to get enough GPM to your jets if you go through the pump and heater. Assuming 10gpm for each jet, I would need 120gpm with the current setup and it seems a separate pump would do a better job, that way the pool pump would be shared with the SPA just for circulation and the jets would be operated on that second pump. It seems this is what Allen has on his configuration.
If I go with only one pump it would mean that while I use the SPA, the circulation to the pool would stop to have enough flow to the jets correct? and when the SPA is not in use, the jets would serve as returns ? would you do just one spa drain in this situation?
Regarding pipe sizes. 3'' for the SPA is what I wanted to go with. The pool drain with 2.5'' (but now I have to read more about whether I can do withtout drains. I was thinking that since I wanted each skimmer to be plumbed separately that 2'' would be enough ? Do I really need 2.5'' if they are independent ?
No, the chem feeder is the placeholder for the SWG, I should rename it. Regarding the bypass, I was reading about the fact that it was recommended for pumps able to generate more than 120 GPM and was considering adding it as well. It seems Pentair has a kit with an intellivalve so I'll probably get this one.
Again thanks those advices!
