Hi! My pool heater started leaking underneath. I hired a local pro from yelp to install a bypass valve for my heater I'm not prepared to buy a new heater right now and he say it "wasn't worth" fixing. Instead, without asking, he cut out all the plumbing to my heater and took it with him in his truck when I wasn't looking, flexed apart the remaining short pipes and glued in two plastic connectors (see before and after photos). Is this done correctly? Now I can't install a new heater because he took my plumbing. He said he cut out my plumbing because my pipes are "warped" so his connectors don't fit. He said I need all new plumbing from my salt cell and to my filter due to "warped pipes" so he can install a connector to bypass the heater. I can't run my filter. Thoughts?
