Hello Everyone,
I opened my pool a little over two weeks ago. I usually have a bit of chemical balancing to do, but the water is clear. This year, the water became cloudy once the pump started running and has remained cloudy since.
The FC levels have never been below 15 with the CYA of 25 (I'm currently adding more to get thisa bit higher) since opening, so I don't believe a SLAM is the solution. I have a DE filter that I've backwashed and replaced the DE in 3 times since opening (I actually added too much DE at one point and the excess added to the cloudiness x_x).
I went and bought a flocculent to try, but I'm hesitant to use it. In part because I've never used one before, and also because I would only be able to remove the solid material via my pool robot's basket, which would very time consuming.
I'm happy to answer any questions anyone has, and I'm open to suggestions. Thank you.
