Hi all, I've been using the TFP methods for several years with good results.
This fall my waterflow reduced dramatically, which I assumed would be solved by cleaning the cartridges, but that didn't work, and even installing brand new Pleatco cartridges yielded no improvement.
When my filter was new a few years ago, I got 50gpm at 2200rpm. Now I get 25gpm, even with the brand new cartridges (installed today). I am perplexed about what could cause such a huge reduction. My plumbing hasn't changed and there are no visible/obvious problems. When I adjust the valves to pull or return water only from/to the pool or hot tub, there is no significant change, which I think rules out a blocked pipe.
The only thing I can't bypass is the pump, the filter, the heater, and some check valves on the return lines. I don't know how to diagnose whether the pump is misreporting gpm, or whether the heater or check valves are severely restricting flow.
I got lazy with calcium & pH control this summer, and my saturation index was probably 0.7 - 1.0 for most of the summer. Could that cause tremendous scale buildup somewhere (in the heater?) that is restricting flow? Is there any way to confirm or fix that issue? I am stuck.
FC 1.0
CC 0.0
pH 8.0
TA 110
CH 575
CYA 35
Oh, also, the heater hasn't run in several years, and is actually unable to run due to a gas line problem I never fixed.
FC 1.0
CC 0.0
pH 8.0
TA 110
CH 575
CYA 35
