Just so you know, I think you are way closer than you think..you've done such a good job getting the **** out...if you would just get the kit so you weren't working blind you could nail this and not look back. The clarity combined with color could mean if not for iron (which if present, can add yellow color to blue to get green appearance) you might be darn near clear right now.
However, In your pool store readings, if at all accurate, your CYA at 97 is going to be a problem, as you've probably read in pool school. So a a series of partial water changes would be in order (eg with vinyl liner, 30% would be safe as long as that leaves a foot or two in shallow end.) that will also help with the iron if your supply water is iron free.
There are a couple of "good" TFP-recommended metal sequestrants that would (in the future) help control the iron and ultimately clear up any water discoloration.
But first, you'd need to address the high CYA, then through testing to know you're finished the slam...because they don't work well with high chlorine.
Post back if you're up for continuing the quest after the party and we'll help you sort it out. You could always give your daughter the TFTkit as a present and tell her you're going to teach her chemistry!
That way you'd have a pool girl o help out!
