This picture was taken earlier today...
Now for the tricky part... trying to get the quote here right...
I actually spend a lot of time on E-Bay... and came across the Stenner for $85 "New but the box had been opened" with shipping included, so I couldn't resist! Yes, I did the install myself, it was EASY!
I love the stenner... I don't have to worry about low salt/high salt/low flow warnings that a SWG will give you... it just works!
I get my bleach (12.5%) from a local chemical supply house 55 gallons at a time. I buried the first barrel beside the equipment pad (the black circle you see in the picture between the uprights for the electrical) to try to keep it cooler in the Alabama heat. From there, I just siphon into it to re-fill. I also bought a cheap hand pump for the barrel so I can open one of the bungs, and pump out bleach if the wife needs some for the house, or a neighbour needs some for their pool.
On the electrical station in the picture, you see 2 timers (One on each side of the outlet). The one on the left is for the Stenner... the one on the right is for the pool pump. I have the Stenner set to come on 15 minutes after the pool, and run for 1/2hr. This happens twice per day, once in the AM, and again 12 hrs later in the PM. The pool pump comes on at 6, the Stenner comes on at 6:15 then shuts down at 6:45 The pool pump shuts down at 10. (The pool pump is set to LOW speed). I figured that I would get the flow started... then the Stenner could do it's thing... then 3+ hours of nothing but pool water going through the pipe would be PLENTY to ensure that the chlorine was in the pool, and not sitting in the return pipe. The only time the pool pump goes to high speed is if I am doing a manual vacuuming, or if I need to backwash the filter.
With me running the pump this way, I estimate that the pool pump, and the Stenner are costing me less than $15/mo to operate, so it is a WIN!
The PVC pipe that you see banded to the pool supports my over the wall skimmer... since I added an overlap liner, and run my water as HIGH as it will go, instead of the regular... (52" pool = 48" water)... my pool is actually 51.5" water level. (I am trying to figure out how to make it into a "Dunk Pool" with a 10ft depth... 52" above ground, and the rest under ground). If I didn't Raise the bracket for the skimmer, the floating weir would just float out of it. (The skimmer would sit too low in the water)
I welcome any further questions/suggestions.
![OP3dQtX.jpg](http://i.imgur.com/OP3dQtX.jpg)
Hi Ron,
Not to hijack the thread but nice set-up, How is the Stenner pump doing, did you install yourself, I am planning an upgrade and torn between SWG and Stenner, and just when I eliminate the liquidator I read something good about that. I read about 1 person getting a Stenner online for $200 bucks, that is darn good price and leaning that way, but SWG still seems the least work. I have been doing adding liquid chlorine manually when home and when I go away I use the chlorinator and then adjust to new CYA or replace water. What are your pro's and cons on 2 speed vs variable speed on pump. If we take this for more than a post or 2 we can start new thread, sorry PoolID for the little hijack.
Also what is the pvc pipe for that is banded to the pool support at the far right of the picture
