My Pentair pump is only a few months old but it started leaking small amounts of water. I called Pentair and they sent someone to come check my pump since it was under warranty. The technician showed me where certain pieces of the pump had become damaged from over heating and he said the likely cause was the pump priming dry. I actually had my pump prime dry a few times after the pool was first installed but I know there was a mechanism that shut the pump off a few seconds of failing to prime. So with this mechanism in place, I asked him how the pump could have overheated. He then said it might have been that my pool water level was low, but I also explained that I had an auto-fill system and I've never seen the pool level drop. He didn't have any further explanations but simply said Pentair's warranty wouldn't cover it. I ended up have to pay for the service and parts out of pocket.
I'd like to know if anyone else has experienced this issue. It strike me as odd that Pentair can use this excuses for not honoring the warranty. I feel like they could pretty much blame user error for any warranty issue.
