My pool pump finally died last season and I'm buying a new one for this season. My question is what power VS should I get? My pool, heat pump and current pump are listed in my signature. I have been reading a ton about the savings between VS and single speed for awhile now but still have questions. The more I read the more questions Inseem to have so here they are.
1. What size do I need? I currently have a 1 hp pump so I can I replace directly with a 1 hp VS? How exactly do I determine the replacement VS size if I can't match 1:1?
2. I live in north Idaho and my heat pump runs a lot during the season so I'd be more interested in running at the minimum speed necessary to meet my heat pumps flow requirements unless I could easily get the heat pump to call for water when turning on.......is there any easy way of doing this?
3. Can VS pumps still give significant saving if left to run a lower speeds and not turned off throughout the day? I'm having a hard time finding power consumption for the lower speeds.
Thanks for taking the time to read this far. This site is an amazing source of information. You taught me the simplest way to keep my water clear and balanced and now I trust you more than the salesman at the local shop (they just want me to upgrade to a 2hp pump and can't explain why other than my pool is large).
