My pump broke a week ago and I am closing
Aug 7, 2017
1
Pa
I have a inground 30,000 gal vinyl pool and a week ago my pump stopped running. I want to close now and put a new pump in come spring. It is starting to turn green. Of course I would like to close clean. What do you suggest? More chlorine? And algicide?
Thank you in advance
You will need to vacuum out the dead algae if your if you can not pump through the filter.
You can purchase a submersible pump and connect a hose to it to reach the opposite side of the pool so you can circulate.
Only add chlorine. We use the SLAM Process. How do you test your pool water.
I would try to kill and vacuum out as much algae as you can, then close.
