I am SLAMMING and wanted a second opinion of CYA before starting the test. Thread here.
Went down to the local SO MD pool store and found they are charging $10 to test the water, unless you buy something. Tough times I guess....So, I figured I'd buy a gallon of 31.25 Muriatic Acid....and was SHOCKED AT THE PRICE: $15.90. One gallon. I'm not sure how much longer we can get by with these non-stop price accelerations. Geez.
HOW MUCH ARE YOU PAYING AND WHERE FOR MURIATIC ACID? We are sort of in the middle of a fairly low population density...not a lot of Big Box Stores within 25 miles.....Thanks
White "Latte Foam" Covering Entire Pool on Opening
This is not a problem, I am just curious: what is the chemical cause of the "latte" foam on my pool surface. Photos attached. I just removed the cover and all plugs, raked out all the leaves (not a lot this year!!!), ran my pool robot vac to get the stuff the leaf rake can't......and filled the...
www.troublefreepool.com
