mas985 said:I like to focus on the technical stuff. So does that mean you have 6 separate 2" return lines pool to pad? That might result in the return head loss being lower than the suction head loss which could be problematic for the pump. 3 - 2" pool to pad lines feeding two returns each including the urns may be a more balanced plumbing setup.
Optoman said:4 - dinky filter
How dare you speak of my unit as dinky !!!!! :lol:
Any equipment swap out are at cost -- so it's shouldn't be a big deal to upgrade to the filter. But let me share my rationale on why I chose the largest Clean and clear filter over the Plus version. The C&C had sufficient flow capacity, and also you only had to replace one filter. The Clean and clear plus requires replacing 4 filters -- and it was significantly overspeced. Am I just totally missing the boat here ? Is it as simple as.. filter overcapacity trumps everything else?
I quadruple the motion!! I have a 15K gallon pool/spa, a 1 HP (1.85 THP) main pump and 2" plumbing. My builder said that I wouldn't need anything larger than a 200 sq ft. cartridge. So, I, being rebellious and onery, insisted on a 425 sq ft cartridge filter. The added cost... wait for this... was $50.00. When I open my cartridge filter in late May, for its once-a-year cleaning, it looks as though it's brand new. Yeah, 4 cartridges requires about 3 hours of spray-washing to access and clean out each of the pleats... but it's a one time per year task and the PSI never varies.renovxpt said:I third that motion, definitely go with a larger filter.
Optoman said:Hi Everyone -- Thank you for all of your responses.
2 - my error:
I need to alter something in the description of the pool I laid out .... apparently the two main drains are t-ed together for safety reasons down in Florida, so it is only *two* suction lines. One from the skimmer, and 1 from the T-ed together main drains. Does that significantly change things ?
5 - 2.5" on the pad.
I take that to mean 2.5" pipe for the pad plumbing -- but where would the reduction to 2" occur?
Thanks again for all the advice. gunite showing up tomorrow.....
Sorry, no one here understands what you're talking about. Please explain this double something'r'other in explicit and exhaustive detail and without using any actual or metaphorical reference to anatomy. (Remember, this is a family site.) What are you waiting for?I was offering a double entendre on having "small unit" and "dinky" being in the same sentence
polyvue said:Sorry, no one here understands what you're talking about. Please explain this double something'r'other in explicit and exhaustive detail and without using any actual or metaphorical reference to anatomy. (Remember, this is a family site.) What are you waiting for?I was offering a double entendre on having "small unit" and "dinky" being in the same sentence
OMGOptoman said:No insult taken -- I was offering a double entendre on having "small unit" and "dinky" being in the same sentence
Thx
Your absolutely correct, this is what mas985 was describing.Optoman said:I think I understand the 2.5 section. Just to regurgitate -- it's basically upsizing to 2.5 wherever all of the water is combined into 1 pipe (suction valve -> pump -> filter -> return valve).
polyvue said:And, for the record: I'm not now, nor have I ever been, a member of any party or club that would have someone like me for a member.
Hrmph.
