- Oct 8, 2020
- 547
- Plaster
- Jandy Aquapure 1400
I've brought up this issue before, and ultimately concluded that because my plaster is new, my pH levels rise quickly and thus the cycle of adding acid every two days isn't unusual.
My pool opened in March 2023, and I can't help but remain bewildered and concerned with how fast my pH rises. If you look at my most recent Pool Math logs as of today, you'll see that 19 hours ago (on 4/11/2024), I added roughly 20oz of MA to bring my pH from 8.2 to 7.5. Then, less than 24 hours later on 4/12, I tested pH again and we're back up to 8.2 (it's probably actually 8.0 but my tftestkits comparator isn't granular enough).
Again: I do not have any sheers, slides, or bubblers running. The only automation I have is to run spillover mode for 20 minutes twice a day to cycle chlorine in the spa. And given the current water temperature, no one is using the pool.
Isn't it weird for pH to go from 7.5 to 8.2 in less than 24 hours? I can't help but feel like I'm doing something horribly wrong, although I'm not sure what that could be. The only other thing I'll point out is that I notice some marks/discoloration on my plaster on the deep end where I consistently pour MA. I make sure to brush thoroughly immediately after I add it, to spread it around and prevent that issue. Seems unrelated to me, but I wanted to point it out just in case. I can take pics if needed.
