I've lived in my house with an in-ground pool since 2010. I paid a pool company to open it the first year and I watched them and took notes. I've opened it every year since. About five or six years ago, I started closing it myself. So far no issues!
Today I went to close it and my compressor is dead. My ShopVac (6HP) has never been able to blow the main drain, so I put the cover on and set out to either find a new compressor (which I've never felt comfortable using for this purpose, BTW) or finally buy a Cyclone like the pool guys used.
Curious how they worked, I found this video on Youtube and my mind has been blown. First off, I've always hooked my compressor up to the drain plug on the pump which blew water OUT of the skimmer (and jets) but he's doing it the other way!?! But where my mind gets blown is he uses the second hole to blow out the main drain. That scared me! You see, I have two holes in the bottom of my - one and only - skimmer but one of the holes is capped off and I've never removed that cap in 12 years!
1. Have I been doing this wrong the entire time by leaving the one hole capped in the bottom of the skimmer? Am I supposed to have two open holes in the bottom of my skimmer when my pool is running?
2. Assuming I am indeed supposed to have two holes open, if I buy the Cyclone, I can see how you would blow it out through the skimmer holes but how do you get an air lock? With my compressor and pump drain plug method, I would shut off the main drain valve when the air bubbles started coming out and get a good air lock. I'm confused about how this works the way the guy in the video is doing it. Doesn't the water just rush back in the main drain when he turns off the Cyclone?
3. Maybe I should just stay with my tried and true compressor method and pump drain plugs?
Help me out here!
Help me out here!
