I think I have this right, but I want to double-check. I'm connecting a compressor to the drain of a Haywood Super Pump. If I set the multiport to closed, it will block the air flow, forcing it back through the suction side so I can blow out the skimmer, etc. Is this good, or should I instead use an expanding plug inside the pump, blocking the return side, to avoid any slight chance of damaging the spider gasket?
Then, to blow out the returns, I can either use that same plug on the suction end of the pump or turn off the suction valves. Any preference there?
