The diverter seal also seals the body on those valves. Part number 272409.Hey all!
Pool opened up with minimal fanfare There is a leak at the multiport, which aside from losing water/chemicals, I believe is letting air into the system causing the pump to deprime after it stops running. Is this a simple case of having to replace a gasket or something else?
Good catch. Certainly something you can handle.I believe is letting air into the system causing the pump to deprime after it stops running.
The diagram only indicates one gasket, part 10. There is an O ring on the stem, part 8 that you can try to replace, but the leak seems to be at the separation of the top and bottom unless it is running down from the handle. Be very careful disassembling the top. That spring is very strong and it has to be re-assembled exactly as in the diagram. All of the parts are listed on the 6th page of the attached PDF.
You might find it easier to replace the valve top assembly, #272422. Here is one place that has them:It looks like only the stem oring is contributing to the leak rather than the spider gasket as i originally thought. Is it worthwhile to do both since I'm opening it up or leave well enough alone and just do the stem?
Pentair HiFlow Valve Top Assembly 272422
Replacement Top Assembly for Pentair HiFlow Valves (261049, 261050 and 261142 models).sunplay.com
If it was me and I was just replacing parts, I would replace any part that I disturbed so I don't have to go in a second time.
Its the disassembling and reassembly that is a bit difficult. There is (or was) a tool that could be used to compress the spring so that the handle could be re-attached. The spring has to be able to keep the diverter completely sealed against the gasket and you'd be surprised at how much pressure the pump exerts against it. The spring is very strong.The stem oring is that difficult to replace? In comparsion to the cost differential that is ($7 vs $180)?
Not the greatest video, but you get the idea. Turn down the volume, they have some annoying music blasting. Skip to about the 1 minute mark.
