- Jul 30, 2012
- 12
So when I turn on the pump it works great. Moving water and circulating with good power.
After a short time, hour or so when I go back out the pressure gauge is still at same PSI but there is no water being circulated. There's no pressure holding the skimmer basket in either.
I can turn off. Let sit for a while and come back and normally a restart will get the pressure going but not always.
I have check and can't seem to find any thing plugged up.
I rewired it with the white spa hosing as it did this with the cheap gray hosing they installed originally. No leaks. Opening air valve no air comes out, water only.
Pump is around 2 years old. No real concerning noises or screeches from it when running. Blue Torrent I believe it is.
I'm out of ideas.
Thanks
I'm out of ideas.
Thanks
