Maybe dump the SWCG in vinyl pool with aluminum walls?
Slim53
1
Conyers GA
Just had my pool liner replaced and there was A LOT of noticeable corrosion on the aluminum wall panels that are behind the vinyl liner, the pool guy that did the liner told me that was due to the pool being a salt water pool and he scraped the corrosion off but told me it would just return and he suggested that I go back to using chlorine tabs or chlorine bleach to chlorinate the pool, WHAT IS YOUR SUGGESTION? Thanks!
Welcome to the forum!
Why are the walls getting wet from pool water? Only way is a leak. Leaking liner will destroy the walls regardless. All pool water has elevated salt content, regardless of how you chlorinate.
I suggest you read through Pool Care Basics - Trouble Free Pool and even look at a few of our videos TFP-TV - Trouble Free Pool
