Hello - I have the Intelliflo VSF with the control panel (which is remote), it is great to set the pump schedule, but I want to connect my MasterTemp heater to run (have power) only when the pump runs. I have an intelliChlor which came with a communication cable that I do not use because it is on a separate timer. I'd like to use that communication cable with the MasterTemp. How and where do I connect the 2 wire to the heater? And if I do, will the heater turn off when the pump turns off? We do not have a timer since we use the control panel that comes on the Intelliflo VSF.
