- Dec 26, 2019
- 1,839
- Plaster
- Pentair Intellichlor IC-40
So it seems that when you schedule a heater function in your Intellicenter (FW 1.064) that you cannot adjust the control point of the heater during the scheduled time. MasterTemp has the 6 button membrane and the newer control board w/RS485 control and is hooked up via RS485.
Example...
I set my spa to run every Friday from 6-8 pm, in order to exercise the heater to ensure that it is operating properly, and that weekly operation (hopefully) prevents critters from nesting in it. I set the heater at 96 degrees, as that is significantly above the 68 degree minimum required for the MasterTemp operation, and should give it enough heat to burn out any corrosive condensation that might collect during the colder water temp operation.
This evening, the wife decided to take advantage that the spa was already running and went and jumped in. She attempted to adjust it up to 99 (using the Intellicenter) from 96 and while the call for heat signal worked and caused the pump speed to increase and heater bypass valve to operate, the heater was stuck at a 96 degree max setpoint. I didn't think to check if it would allow it to adjust the other direction.
Edit - as soon as the schedule was over, I was able to adjust the temp as expected.
This seems ridiculous to me. Why would I not want the ability to adjust the setpoint? I don't want to necessarily heat to 100 or 104 just to exercise the heater. But I guess I am going to have to if I want the ability to adjust the temps up.
Does anyone else schedule a time for their spa to run and can confirm this is happening? Or is someone willing to create a schedule to test this theory?
--Jeff
Second Edit - added IC FW version to above.
Example...
--Jeff
