My 10 year old Master temp 300 will go thru its start up, I smell gas, it will start and the exhaust is warm then it stops and try’s to start two more times. I pulled the tap off and found what looks to be the U11 LED light on. I already changed the AGS, high limit and flue sensors. I bypassed both sensors on the other side of the heater as well. The igniter has around 50 ohms so it should be good. Any ideas?
