Ok, I'm going to do a full drain/refill while I wait for the already-ordered test kit. I agree it is about a wash in terms of the cost of the bleach compared to the pump rental again.
As long as I don't have to do a 3rd pumping, I've not thrown good money after bad in terms of spending $60 at Harbor Freight to purchase a pump and $20 more on another length of hose. If all this works I won't really NEED a pump each season, so my life is in your hands!
After work, the steps:
1. Rent pump.
2. Finish draining
3. Bleach wash the walls
4. Remove as much debris in the bottom as possible (I have a wet vac)
5. Begin refill
ADVICE NEEDED: With this clean water to be refilled, at what point during the refill (?) do I test the water, even with my test strips for a basic view, and add something? Do I just let it go as-is until the good test kit arises, filling up and leaving it? Do I add some liquid chlorine based on the test strip measurements to help insure some level of protection? The last thing I want to see is another bloom in progress before the test kit arrives, but I really do not know how long tap water can sit in a pool before it starts to turn.
With a full refill, and basically no CYA, I see here the recommendation to add some. I've seen it for sale in home centers as a product. Is it better to buy some of that or to maybe use just one tablet to get that amount of CYA to buffer the liquid chlorine? One tablet, part of a tablet, buy the product and put some in that way - what would you suggest here?
1. Rent pump.
2. Finish draining
5. Begin refill
