The day after our leathered marble (Royal Beige by Tile Paver Source) was installed and sanded, a rust color has been seeping through the tile under the porch. This has not occurred where the tile was mortared around the pool. I suspect this is due to the paver base not being appropriate sand. Does anyone know what the appropriate sand base for marble is? What they used looked like limestone but I’ve heard that you should only use crushed granite. The PM said I just need to wash it off with water a bunch of times and it will go away. All this does is mask the color when the stone is wet, and definitely doesn’t remove the stain. Again, this started the day after the install and no amount of water and scrubbing has helped. Any suggestions?
