Manual or robot for first vacuum
dcounsell
2
Baltimore, Md
Hello all,
I am a new owner of an old pool. I am opening it for the first time and had tons of algae. I killed the algae and there is a bunch of debris and presumably dead algae at the bottom. Like alot!. Should I manually vacuum all that once or am I good to just plop my brand spanking new dolphin premier in there and see what happens? If so should I use the ultra fine filter or start with the regular one?
Thanks so much
Hello all,
Thanks so much
I would manual vacuum and if you have a waste setting that would be better then putting all that algae in the main filter.
Can you scoop any of it out with a net?
