Recently I noticed that my Pentair Rebel suction side vacuum was moving a lot slower & was not climbing the walls as easy as it had in the past. Unfortunately there are two things that I suspect to be culprits and wasn't paying too much attention to the issue until this week so not sure which one might be the actual root cause.
Last week I had an electric heater installed to my existing pool setup (Hydro Royal HR125) and I noticed that after the install the flow gauge above my cartridge filter was reading lower than normal. Since the heater is after the pump I didn't think this would cause an issue with the vacuum not moving as it used to. Is it okay if the pressure guage on my filter dropped by 1-2 bar after the heater install?
I also noticed last week that my skimmer basket had broken on the bottom so I wonder if something got through it and made its way into the line between the skimmer & the pump. I don't see anything in the pump side basket so not sure if that's something that can happen, but just thinking out loud.
Any thoughts, or insight or where else to look would be greatly appreciated.
