I am having trouble with low skimmer suction. The filters are brand new and running at 10 psi. The skimmer suction is lower than normal (been this way since reopening last month). It's low when I shut off the main drain on the Jandy valve. What's odd to me is the suction improves in the skimmer basket when I turn on the pop up jet pump. Is that normal? When both pumps are running the psi is still around 10.
These are Jandy Stealth pumps.
The pumps sound normal. The skimmer/drain pump sounds really good---not noisy at all. The pop up jet pump is more noisy---it makes a gurgling sound. Both have been refurbished in the past two years although I am not ruling out a bad pump.
My pop up jet pressure is also low around 10 psi for all of the stations except one. One station will have a psi around 14, but the rest have low pressure. The valve system is two years old.
The filters are new. The skimmer and pump baskets are all clean. I just put new lids on the pumps. I didn't pull anything out potentially clogging the impeller when I put a coat hanger in there. The pumps seemed primed, but I'm not an expert. Water level at the skimmer is a bit higher than in the middle and it seems like enough water is getting in there. There's some suction, especially when I turn on the pop up pump so water is getting in there, but I wake up every morning after running the system all night and the top of the pool is still fairly covered in small bits of debris.
I tried a drainx hose attachment to see if anything was clogged at the skimmer to the pump and nothing came out and nothing changed.
I don't see any water leaks.
I appreciate any insight. Thank you!
