I'm trying to figure out how to use the Intex Deluxe Wall Mount Surface Skimmer (model #28000E) with Ultra XTR Pool (18ft x 9ft x 52in, model #26355EH) and Krystal Clear Sand Filter Pump (16in, model 26679EG).
Without the skimmer, everything functions normally, but once I install the skimmer and cover one intake valve with the flow reduction plug (it's not in the instructions, but the plug came with the skimmer and I figured it's what you're supposed to do), the pump pressure drops below normal (under the green zone in the pressure gauge) and I get a lot of bubbles in the leaf collection basket. If I remove the plug, the pressure goes back to normal, the bubbles disappear, but the skimmer does not suck much.
I read some posts on the topic and it seems like the recommendation is to use the flow reduction plug or plug one intake valve completely. I tried doing both, but after a few hours I got the low pressure error (error 90) on the pump. I'm not sure if this can cause the pump to fail, but I removed the plug for now until I can figure out the correct way.
One thing worth mentioning is that the I'm using a more powerful pump than recommended, but I asked Intex and they said it should be okay. I'd also like to understand the physics of it. Since the hoses connected to the intake valves have smaller diameter than the 1.5" hose that connects them at the Y-splitter to the pump, if you block one of the intake hoses, wouldn't it cause issues?
Any ideas?
Any ideas?
