Hello everyone - I have a 10 by 5 metre pool and the pool pump normally operates at about 10PSI but after backwashing and rinsing last week it's dropped to 5PSI - I've re-backwashed and re-rinsed and checked the skimmers and the filter and it all looks OK but the low pressure persists. I've called out the pool people to come and look but I don't know when they might turn up (it might be a week) and I wanted to check given the very hot weather we're having if it's bad for the pump to run 24 hours at that low pressure (my return flow rate seems normal). Many thanks for your help!
