I'm looking to see if there's any info out there about replacing the bearings in the motor for this pump when I do a planned seal/impeller replacement. I swear I've seen that the impeller was a noise generator in these pumps before. Can't find it now.
This pump is ridiculously loud.
All I know is the motor uses one of each bearing, a 6203 and a 6204. I assume double-contact sealed, stainless steel deep grove ball bearings are what's needed.
I just haven't seen if anyone has been successful at replacing these, and if there are any other seals, etc required for the motor itself.
Hoping to not have to drop $350-400 on a motor, when this one is only about 4 years old.
Thanks!
Thanks!
