carlscan26 said:
lightingguy said:
Your leak is so bizarre. How does a leak big enough to drain an entire pool just stop?
Could it have been due to a siphon effect with that pipe that is used for draining water behind the liner? Depending on how the jandy valve was turned maybe?
I'd put a separate valve on that one too if you didn't already when you added the valves to your pool suction lines.
It shouldn't have been. I thought about that too, but once it started losing water I closed that valve so that no water would be going to the pump, unless it left the connection between the skimmers/main to the drain pipe open and siphoned water that way?? That would be the only way that could have happened. I don't know how the valve looks when closed, maybe someone can enlighten us on whether that could be the case.
