I am the owner of an great Artic Klondike and running it the tfp method with chlorine an hydrochloric acid. In one of the pipes I made a T-fitting where a ball valve (VDL PVC Kogelkraan 2 x binnendraad - PVCbuis) is attached to which a hose goes to a perstaltic pump (Slangenpomp MP2-R (01-03) - Dutch Water Tech - Waterbehandeling) powered by 230V AC
The pump is set to a small 10mL/minute flow and is switch on and off by a timer twice a day for 43 minutes
Big problem is the injector connected to the ball valve which always dissolves because of the chlorine and now I am looking for a Stenner solution.
I think the Stenner Econ VX (Stenner peristaltic pumps Econ VX adjustable, FX fixed on and off metering) would be a good replacement for the pump but now the tubing/injector part. Looking at the current solution i think i need:
- Pump (my bet would be the Stenner Econ VX 2,1mL to 102,- mL per minute)
- Mounting bracket for mounting to a side wall
- check-valve to connect to the ball valve so it need to have 1/2"thread on the outside
- tubing from ball valve to the pump (appr 15 feet)
- pump tube
- suction tube from barrel to pump (appr 2 feet)
All resistent to 12,5% Sodium Hypochlorite (Chlorine)
Anyone who could translate this into a part number list?
I asked Stenner but got brushed off and send to a dealer but i'm not totally sure if i would get the best solution in terms of price/performance.
Yes i'm able to arrange transport from USA to the Netherlands.
Thanks in advance for guidence,
Edwin
- pump tube
Edwin
