- Jun 22, 2014
- 47,861
- Fiberglass
- CircuPool RJ-45 Plus
Wow! You inherited quite a project. Your before and after pics are something to cherish. Good job on the chemicals last night. You're on track! Today we would expect your CYA to be in that 35-40-ish range based on the stabilizer you added, so that's done. Your FC was at about 6 or so last night. Depending on the condition of your water, some of it "may" have be used-up. So you might be able to use your new DPD kit to verify your FC level this morning. Until your new kit arrives, just make sure the FC never drops below 5. When it gets too low, that's when algae tries to bloom. An FC of 5 is a safe number based on your CYA. You can also verify that your PH is between 7.2-7.8.
Aside from that, you're in great shape! Unless your FC starts to go below 5, we typically advise to add your bleach in the evening since it won't be competing with the sun. But if you have to add in the morning or in the day to stay above 5 that's okay. You should be able to limit your pump run times as well. No need to run 24 hrs straight. Maybe back-off to 8 hours, or 4-on, 4-off, or any combination. You'll learn later what works best for you.
When you get your new kit, you'll see how nice it is to have "clear visibility" or your chemical levels without relying on the pool store. It's extremely liberating. If you have any more questions, just let us know. Have a great day!
