You can try it in the drain plug hole and if it works correctly then that's great. You won't have to drill the pipe.
EastKYGuy said:Thanks Bama. Can I put the outlet side in the pump basket drain plug like I've seen suggested here before or do I get better flow by putting it on the pipes?
Bama Rambler said:The best single thing I did was get the 1/4" Hayward needle valve to control the flow out of the LQ.
carlscan26 said:Can you post a link to the non John Guest fittings on the us plastic website? All of the speedfit connectors seem to be that brand...
