Liquid Chlorine question from a new guy
Feb 15, 2013
54
Peoria, Illinois
I started looking locally for liquid chlorine. I found PolyGuard Ultra Shock at Blain's Farm and Fleet for $12.99 for 4 gallons. The specs say Sodium hypochlorite 12.5% by weight. This would work right? Is this a good deal?
I went to the store as I wanted to find the date info. I took some pics. On the outside of the box was 09919 and this number was also printed on the bottles. Any idea how to decode this? I assume it's a date code.
Thanks!
101085 101086 101088
In your basement, a good two or three months. Best idea is to get a months worth now and then resupply as needed.
You can assume you will use at least 3 ppm FC worth per day. More on high swimmer days.
You will use about 25-30 oz per day so 1 gallon will last you about 4 days. Then you'll need a few extras if you have to slam. 10-15 gallons should be a safe purchase
