We had a new linear installed in our pool two years ago. Not a great job in my opinion. Liner kept pulling out of the to track, leaks etc.
This year still more leaks. I found a spot near the light where it looks like the liner had either turn or pulled out from the light ring.
It's a triangle shape about .5" wide at the light ring and extending about .5" to the point of the tear/hole.
It also looks like someone has placed an extra piece of vinyl under the light clamp ring and over this hole, like flapper valve.
Couple questions.
1) Am I justed headed for trouble here? Looking at it seems like this will just get bigger.
2) is this something that can be fixed with a patch? I would guess it can't without taking the clamp ring off.
3) do I have any recourse going back to the original installer? I think this is far more of an issue with a poor original install than anything else but I have no idea what "industry standard" is on something like this. The liner has a warranty but I would doing the labor does and this is a labor issue.
I would take a picture but it's under water and at a bit so good position on the light.
Thank you for any thoughts.
Couple questions.
