I have a 22 year old pool. Need to change the light. Pool guy quoted $950 to switch to led. Decided to just change the bulb myself and punt that expense.
I took it out. Had some water in the light.
I bought the same bulb at pitch a penny.
But I also need to replace the metal ring but would actually like to replace all those pieces to ensure it’s air tight. The ring busted slit has to be replaced at a minimum.
local pinch a penny and Leslie’s pools weren’t able to help at all.
Could use some help determining what I need to order exactly and where I can do so.
