chemmy, unfortunately, if you don't drain and refill the pool, you most definitely won't be swimming for Memorial Day.
My 15X42 was just like that a few weeks ago. Knowing my "formula" from last year, I started dumping bleach. Started off with 1 gal per thousand which is a little more than 4X the daily maintenance dose. I would spend a few minutes each day scooping, then run the filter for 4 hours.
One thing I do have left to do is clean out the flap at the base of the side walls, where it joins the bottom. Got some extra material there that traps some greenery and leaf litter. Thinking about getting a nice fresh envelope opener and slicing away the excess vinyl.
No worries, my FC drifted down a little when I checked it this afternoon, so I used Pool Math and added the appropriate amount of bleach, swept, skimmed, and turned on the filter.Dont use my formula, it is based on my pool and situation! Do the SLAM as advised! Looks like good numbers, so just concentrate on getting that debris out, as much as you can each day until the visibility is bad. With mine, it was 4 or 5 scoops of the net, since the debris had gathered together in the center of the pool. Minutes of effort, paying off as my pool approaches crystal clear!
