LED bulb for 20yr old Spa?
Restomod
Active member
Apr 11, 2014
33
Dallas,Tx
Hi everyone I'm looking a color changing Led replacement bulb for my older build spillover spa. I contacted INYO Pools and they could not confirm fitment being the housing is older. Any ideas?
Here are the bulbs I was considering, not wanting to spend $1k per bulb.
And here is what I have...
Reactions: Restomod
You have a Hayward Astrolite II SP590SL light.
Click through the bulbs and read the compatibility.
This Pureline bulb says it is compatible with the Astrolite II...
I haven't clicked through all of them but you should be able to sort them into don't fit, maybe fit, says it is compatible
Thanks, I told them the I believe the PL586 would fit, they said they were not sure of the niche being compatible?
What do you expect them to say? They don't know anymore then you do.
Buy it. Try it. If it does not fit then return it.
Reactions: Restomod
