I thought it would be beneficial for others to hear from someone that was not brand new to TFP and had "some" knowledge of pool chemistry.
The pool industry really does a good job at making you believe things that are not true and that resulted in my stubbornness to accept the ways of TFP/
Keeping Chlorine levels High - Understanding that I had to boost my chorine to compensate for CYA took a while for me to accept.
TA - I thought that keeping TA between 80-120 was ideal. So I tried to keep it at 100. This required me to constantly add baking soda. Knowing now that its OK to keep at 60 (where it settled at), I haven't added any baking Soda .
PH - This is a tough one to accept. Logically you think anything above 7 (neutral) can lead to scale. 7.8 is the top end so I always tried to keep it around 7.5 or so. This required me to constantly add acid. Now that I keep it at 7.8, I barely add acid anymore. Pool seemed to settle in around 7.8. I don't quite understand it and would be lying if I didn't worry that scale may form. But I am adhering to the process.
SLAM - You have to do this exactly. That means buying the test kids and following all the process without omitting anything.
