My Hayward T-15 cell has developed a serious water leak. Bought a new one on Amazon, that's installed & working ( & not leaking ), now. But I really would like to fix the leaky one. It's only about a year old, and there's plenty of life left in the electrodes.
Popping off the end cap, the problem is obvious; the seal where the wires come out has failed. Cracked in the middle. So I need to
redo it somehow.
It's a hard rubbery substance. I can probably drill & grind it out. But what to seal it with now? Right now, I'm considering polyurethane caulk. Another - superior - alternative would be a two-part polysulfide sealer, such as 3M "Pro-seal". If polyurethane
is good enough, I'd rather use that. Pro-Seal is a real PITA to deal with. But it would absolutely work. Pro-seal is used to seal aircraft fuel tanks. Overkill....
Another alternative would be to fill the whole cavity with epoxy.
redo it somehow.
