A little backstory real quick, I purchased my home which came with an above ground pool. This is my second year with the pool, but the pool was put up in 2018. Not sure if it matters or not, but a Hayward kit was used for the skimmer, pump, filter, etc..
This year I’ve noticed a leak which conveniently seemed to occur after I completed the SLAM process and got clear blue water. It started as a slow drip every maybe 45-60 seconds. Now it’s a pretty steady drip every 5-10 seconds. Not wanting to drain any water, I held out hoping it wouldn’t get worse but I fear it’s just going to continue on the downhill slope. I’m attaching a picture I found online, but the leak is coming from the “B location” in the picture.
Would this be due to the gasket between the pool wall/skimmer or is there a gasket in between where it looks like those are two separate pieces to the skimmer itself? Also do I have to drain, fix, then refill or is this something I can get some marine grade sealant to hold me through the rest of pool season?
