Hello,
I noticed a leak around the Circupool SJ salt cell where the cap threads into the housing after taking out the cell to clean it. I have changed the O-ring, placed plumbers tape on the threads and tinkered with it dozens of times but it still leaks/drips which accumulates a large amount of water overnight. It is not a defect in the plastic housing as when I place a winter cap on the housing instead of the salt cell it does not leak. It seems that the salt cell no longer provides a water tight seal. The only thing I can see when looking at the cell itself is a small indentation on the area that presses against the O-ring (picture attached). Would this be enough to cause a leak? I was going to try to fill this in with a plastic repair epoxy but wondering if anyone has any other ideas or experience with this. Thanks.
