Hi everyone- we finished construction on our pool about 8 months ago although we are technically not “done” with our builder. Final inspection has yet to happen and we have not made the final payment.
Over these months we have noted that there may be a very slow leak somewhere in the system. But with the 110 days we assumed it was evaporation. Now as we’ve moved into cool weather and have had the pool closed (built in cover), we are questioning if it really is a leak since we are still losing about an inch -2 a week even while fully covered.
We have also noticed that of the 4 water ports in the spa (built into the pool), only 2 have pressure and 1 actually has suction when turned on.
Is there anything we can do other than the bucket test to verify a leak before making a fuss to the builder? Does the spa issue indicate a leak in any way?
Thank you!
Thank you!
